Vesconite Anticipates Movie Prop Platform Orders in 2025
A provider of engineering services in the hydraulic and pneumatic industry anticipates new orders in 2025 for movie prop platforms that use low-coefficient-of-friction Vesconite bushings. It hopes to produce several platforms in 2025, which will add to the number of platforms that it has produced since its first foray into the movie industry in May 2005.
These platforms are engineered to handle heavy movie props, some of which weigh up to 40 tons. Using hydraulic technology and control systems, the platforms are capable of tilting props from side to side by 10 degrees, providing the necessary movement for realistic and dynamic cinematic effects.
Each platform is equipped with several Vesconite bushings, laid out in a configuration to suit the movement required for each specific application. These bushings are mounted on a 100 mm steel shaft and ensure the smooth motion of the system.
While the hydraulic system supplier to the movie industry cannot divulge specific details about the movie props due to confidentiality agreements within the film industry, it is known that the engineering firm supplies several production companies in Cape Town, South Africa.“Vesconite Bearings is proud to be part of creative solutions for movie props that are often highly memorable components in films,” says Vesconite Bearings’ Nadia Swart.
vesconite.com
