Steigentech Launches High-Performance V-Belt During Hannover Messe
The Steigentech PowerPlus EPDM CRE V-belt range has been designed to keep HVAC equipment, compressors, fans and ventilators or tool machines running. Because of their technically-advanced material and design construction, these belts can be installed easily for smooth running, with no need for re-tensioning. As a result, machine uptime is maximized, and maintenance and service time is minimized.
The V-belt is a high-performance cogged raw edge product (CRE) that incorporates high tensile cord to ensure improved energy efficiency and drive performance. The advanced V-belt with maintenance-free operation allows installation without re-tensioning, reducing downtime and replacement costs. With lower tension decay, minimal stretch and high flex capability, the V-belt is ideal for systems with compact designs.
Steigentech works consistently with extremely tight manufacturing tolerances across the entire range. This ensures that customers can confidently select any PowerPlus V-belt from stock and be sure that no matching is required. This means that maximum load transmission is ensured across the application, with worry-free ‘fit & forget’ installation. The V-belt is available in single and banded versions in the usual sections.
