Stafford Offers Adjustable Positioning Shaft Collars
A line of adjustable shaft collars that are designed to provide for the precise linear location of shaft-mounted components has been introduced by Stafford Manufacturing Corp. of Wilmington, Massachusetts.
Stafford Adjustable Shaft Collars feature a Micro-Adjustable shaft collar for applications requiring repeatable fine-tune positioning in 0.0005” increments with 0.200” total adjustment; an Adjustable Thrust Collar that provides bi-directional axial adjustability with superior holding power; and a Micro-Adjust Stop Collar Assembly that offers micrometer-like adjustability of either or both collar faces.
Designed to let users precisely locate shaft mounted components for a wide range of industrial automation, material handling, packaging, and robotics applications, Stafford Adjustable Shaft Collars are offered from stock in standard 3/8” to 1-1/2” bore sizes made from steel and stainless steel.  Special sizes and materials can be supplied.
