Manufacturing Mining Drive Systems Drives Gear Drives Gears Product News
SEW-Eurodrive Launches XMiner Industrial Gear Units
The alignment-free plug-and-play design simplifies installation, while the Taconite heavy-duty sealing system for abrasive environments like mining and cement, features grease purge-able labyrinth seals and laminar rings to prevent debris from entering the gear unit.
"We designed our XMiner Industrial Gear Units to reduce the hassle of machine design, installation, operation, and maintenance of heavy-duty conveyors. The XMiner’s design ensures a quick and flexible setup, significantly reducing downtime. This product meets the mining industry's rigorous demands while enhancing operational efficiency," said Austin Burdette, product and business development manager – industrial gearing, SEW-Eurodrive.
The XMiner features gear ratios ranging from 6.3 – 450 in 2, 3, and 4-stage configurations with output torque to 1,637,389 lb-in in multiple finely-stepped frame sizes.
"The XMiner Industrial Gear Units provide top-tier technology with unmatched availability and service. SEW-Eurodrive's extensive local support guarantees rapid access to parts and expert assistance, ensuring reliable heavy industry operations," said Mark Jones, director of sales – industrial gearing, SEW-Eurodrive.
Key features and benefits include:
Features:
  • Reversible housing; can be inverted for either right-hand or left-hand shaft location
  • Extremely robust housing
  • Helical-bevel gear unit
  • Single-piece or split-gear unit housing
  • Numerous torque arm anchor mounting locations
  • Distinctive modular technology
  • Large selection of standard accessories
  • Either CCW or CW rotation
Benefits:
  • High power density reduces weight and cost
  • Patented cooling systems eliminate the need for expensive cooling alternatives
  • Reduced inventory/spares
  • Local engineering and application support provided for proper sizing
  • Quick delivery times for standard versions and spare parts
  • Worldwide service and customization options are available
SEW-Eurodrive will showcase its mining products and technologies at MINExpo 2024 in Booth #8695.
seweurodrive.com
