Food & Beverage Conveyor Drives Drive Systems Drives Gear Drives Product News
SEW-Eurodrive Introduces WES Series Stainless Steel Drives.
SEW-Eurodrive is proud to introduce the WES Series stainless steel gear unit, a compact, hygienic drive solution that runs cool – even under continuous operation. Unlike worm gear units that overheat, the WES Series integrates SPIROPLAN right-angle gearing, ensuring smooth, reliable performance without excessive heat buildup. Designed for food, beverage, and other hygienic applications, the WES Series is corrosion-resistant, easy to clean, and rated for high-pressure washdowns.
Key Advantages include:
Compact & Efficient: No cooling fan, no hygiene risk—ideal for clean environments.
Always Runs Cool – Safe & Reliable: SPIROPLAN gearing minimizes friction, reducing heat compared to worm gear units. No burn hazards, ensuring worker and product safety.
Hygienic & Washdown-Ready: Rated for aggressive cleaning agents and washdown environments. Seamless, smooth surface prevents bacteria buildup.
Durable & Low Maintenance: High efficiency gearing and lubrication systems extend service life. Lightweight, compact design for easy integration into processing lines.
This article appeared in the April 2025 issue.
Built for Clean, Demanding Environments & Safety
"The WES Series is a breakthrough for industries needing a stainless-steel gear unit that stays cool, clean, and reliable. By integrating SPIROPLAN right-angle gearing, we’ve created a solution that outperforms traditional gear units in hygiene-sensitive applications," said Tom Ellis, industry account specialist at SEW-Eurodrive.
Industries served include food and beverage processing (bottling, packaging and conveyor systems), pharmaceutical and cleanroom (contamination-free motion solutions) and chemical and washdown (corrosion-resistant, sealed for extreme conditions).
seweurodrive.com
