NovaTorque Expands PremiumPlus Motor Line
NovaTorque, Inc., a Fremont CA based producer of ultra efficient, cost-effective, electronically commutated permanent magnet motors, introduces 7.5 hp and 10 hp models of its PremiumPlus+ motors. NovaTorque motors use low-cost ferrite magnets in an innovative flux-focusing design to deliver the superior efficiency of rare-earth permanent magnet motors at a price that is competitive with induction motors. “NovaTorque’s new 7.5 hp and 10 hp versions, driven by variable frequency drives, boast motor-only rated point efficiency of over 94 percent, a full 3 point advantage over NEMA Premium induction motors. That advantage grows under partial load, as is the case in variable speed fan applications, with typical efficiency improvements ranging from 5 to 15 percent. In a high duty cycle 10hp fan application in an average cost of power area, annual energy cost savings can exceed $300,” says Scott Johnson, NovaTorque’s vice president of sales. “The advantage is even more dramatic when compared to the current installed base of induction motors, where efficiency improvements of 20 percent or more are achievable,” continues Johnson.
Importantly, due to its unique patented flux-focusing stator and rotor hub geometry, the NovaTorque motor produces this performance with an all-ferrite (versus rare earth) magnet design. “The cost of rare earth (neodymium) magnet material, the basis of most conventional permanent magnet motors, has risen erratically over the last several years. Further, supply of rare earth magnets is increasingly uncertain. The ability to use ferrite magnets allows NovaTorque to price its motors comparable to induction motors. This means OEMs and HVAC systems builders can now economically deliver superior permanent magnet motor efficiency with modest first cost impact and a rapid payback,” explains Jaffer Hussain, NovaTorque’s vice president of marketing and product management.
NovaTorque PremiumPlus+ motors are packaged in standard NEMA frame sizes and mounting dimensions for easy substitution of AC induction motors. NovaTorque PremiumPlus+ motors are compatible with readily available variable frequency drives (VFDs) from most leading manufacturers, including ABB, Yaskawa, Mitsubishi, Siemens, Fuji, Hitachi, Toshiba, Delta, Danfoss, Schneider, Vacon and others.
