NORD to Display High-Performance Drive Solutions at CONEXPO – CON/AGG 2023
NORD will feature the following products at Booth S-85214:
MAXXDRIVE XD industrial gear units are NORD’s heavy-duty solution designed specifically for crane and hoist applications. They feature an extended center distance to allow for a U-shaped design with the cable drum and motor on the same side of the gear unit. Compared to NORD’s standard, compact MAXXDRIVE series, the XD center distance has been increased by 35 percent. The MAXXDRIVE XD series includes 3-stage and 4-stage reductions with same overall unit dimensions and center distances for a standardized design, and various input and output shaft and coupling options for easy adaptation to applications.
MAXXDRIVE industrial gear units deliver output torques up to 2,495,900 lb-in, high load capacity, and a long service life. They feature NORD’s trademarked UNICASE housing design that ensures precise positioning of bearings and shafts, quiet operation, low maintenance, and increased safety with all joints and components sealed. Due to their robust housing, they can withstand a wide variety of ambient conditions and function both in dusty environments as well as in environments with high humidity, heat, and larger temperature differences. MAXXDRIVES are highly configurable and feature a wide range of options including various output shaft options, output flanges, motor attachments, and input options.
MAXXDRIVE XT industrial gear units drastically reduce spare parts costs and downtime through their universal, symmetrical housing design for mirror image installations. These units were developed for maximum thermal power and mechanical load capacities and due to their ribbed housing, optimized axial fans, and air guide covers, they can achieve very high thermal ratings without the need for external cooling measures. Modularly attached backstops enable easy maintenance access without costly downtime.
NORD’s UNICASE helical bevel gear units offer a wide performance range of 0.16 – 268 hp and torque up to 442,537 lb-in. Specialized heavy-duty bearings and spread bearing/flange mount designs enable these units to produce high load capacity, minimum backlash, and long service life. They also achieve a low Total Cost of Ownership (TCO) due to their low maintenance and high efficiency for low operating costs. With numerous shaft designs, mounting options, and bearing concepts, these versatile units are adaptable to countless applications.
