Harrison Poultry chose NORD DRIVESYSTEMS as the preferred gearmotor supplier for their $52 million dollar facility for several important reasons. NORD distributor partner Campbell Sales in Athens, GA has been a strategic integrator and supplier to the various Harrison facilities for many years, so it made sense to stick with the proven NORD products, service, support, logistics, and expertise which Campbell provides.
"Will Campbell talked me into installing a NORD gearbox at our old feed mill in Winder, Georgia,” says David Sailors, operations manager for Harrison. “That was twenty years ago, and those units are still running. We've bought several others since then with the same results.”
So, with Campbell Sales on board, at that point Sailors, Harrison’s Corporate Project Manager Nick Strange and the rest of the Harrison team set out to design and build an ultra-modern facility with the capacity to support their grain and feed processing needs for the next twenty years and beyond. Hogenson Construction was selected as the general contractor for the massive project.
The Harrison, Hogenson and Campbell teams worked together to specify, size, and select NORD gear reducers and Nord MAXXRIVE industrial gear units. Nord application engineers then worked directly with the various world-class USA manufacturers who would eventually provide the mill systems and equipment, in order to provide guidance on design, assembly and commissioning.
NORD’s Helical Bevel gear units, CLINCHER Parallel Shaft gear units, and MAXXDRIVE industrial gear units offered several product advantages for Harrison.
The NORD solutions eliminated the need for outdated shives/pulleys/belts/guards, etc. They also use a direct-drive concept that is much safer and more efficient. It was also more cost effective for Harrison due to reduced maintenance and service requirements commonly attributed to belts and pulleys. Fewer moving parts also enhanced the overall reliability and reduced the number of wear parts that needed to be stocked.
