Manufacturing Automation Motion Control Gear Drives Gearmotors Gears Motor Controls Motors Variable Frequency Drives Product News
Nord Enhances Efficiency with New Digital Twin and Simulation Capabilities
Virtual commissioning is done via the myNORD Online Customer Portal. Users configure drive systems for their requirements, selecting features such as performance, mounting options or outputs. Once they are done with their selection, they can request a simulation model for the fully configured drive system. This process was developed by NORD in cooperation with machineering GmbH & Co. KG, a software company in Munich specializing in virtual commissioning.
A main advantage of digital twins is the faster availability of the entire system. Models from myNord are inserted into a simulated system, enabling extensive testing before products are ordered and assembled. If adjustments are needed, they can be easily implemented based on the data, with errors being remedied in the early stages of development to avoid potential damage and system downtime later. After the virtual drive system has been tested and validated by the customer, Nord will manufacture and deliver the physical solution. The overall process from configuration to commissioning is reduced from several months to only a few weeks.
Nord’s primary focus for this initial phase of simulation models focuses on components that play a decisive role in automating production processes such as their range of high-efficiency synchronous motors as well as the corresponding gear units and variable frequency drives. Future simulation models will gradually become available for other NORD product areas.
nord.com
