Design Material Handling Packaging Robotics Gear Drives Gearboxes Gears Shafts Product News Gear Design Torque
Harmonic Drive Announces HPF Series
The HPF series hollow shaft gear units provide exceptional torque density and positional accuracy, making them suitable for a wide range of industrial applications including robotics, packaging, and material handling. They feature a high torque output, with maximum continuous torque ratings up to 1,000 Nm and maximum peak torque ratings up to 1500 Nm.
The unique hollow shaft design allows for easy integration and installation in tight spaces, while also allowing for the passage of cables, hoses and other mechanical parts through the gear unit. Additionally, the hollow shaft design also provides a high torsional rigidity, making it suitable for high-speed applications.
Built with state-of-the-art manufacturing processes and materials, the HPF series gear units are durable and reliable even in the most demanding environments. They also feature low backlash and low noise operation, making them ideal for applications where precision and quiet operation are a must.
https://electromate.harmonicdrivegearhead.com/products/harmonic-planetary-gear-units/hpf
