Dunkermotoren BG Series Matches with Simatic Micro-Drive from Siemens
With the brushless DC motors (24 to 48 volts) of the series BG 45, BG 65(S), BG 75 and BG 95, Dunkermotoren has been the market leader in the 20-1100 Watt power range for years. As part of a product partnership with Siemens, the motors are now also available in specific versions compatible with the new Simatic Micro-Drive servo drive system.
The simple integration of the Simatic Mirco-Drive servo drive system into the Simatic world significantly shortens the engineering time. The integration into Siemens automation technology is possible via the TIA portal and simplifies commissioning and service. Communication takes place via Profinet IRT with Profisafe and Profidrive profiles. The new Safety Integrated Function SLT (Safely Limited Torque) ensures a limited torque by monitoring the motor current during operation.
Smart components in the motor, together with a patented data transmission system, set the controller to a preset state after it is connected to the motor. Cumbersome drive tuning and parameterization of the controller control loops are a thing of the past.
