Reliability, flexibility and energy efficiency: Bonfiglioli must-haves for packaging and intralogistics
The flow pack packaging process requires automatic machines that can keep up with high production rates, for which Bonfiglioli offers a wide range of compact, modular, dynamic and high-precision drive and control solutions for both horizontal and vertical forming, filling and sealing machines. These include the package on display during the three-day event, featuring a TQ in-line high precision planetary gearbox combined with a BMD permanent magnet synchronous servomotor and AxiaVert smart inverter, the latter characterized by high application versatility. In addition, the company is able to ensure maximum handling speed for finished products during the palletization process thanks to a solution that incorporates the BMD synchronous servomotor, Series A right-angle gear unit and ANG Series servo inverter.
Two intralogistics solutions were also presented at the fair. The first solution for post and parcel use and airport baggage handling systems consisted of a compact right-angle Series A gear unit available in a wide torque range, the IE4-certified BSR synchronous reluctance motor - an ecological and high-performance product thanks to the absence of magnets, and a DGM MPM decentralized inverter with sensorless vector operation for optimal dynamics control. The second solution designed for roller conveyors combined the EVOX CP helical in-line gearbox with smooth surface that can be fitted to any machine thanks to its compatibility with market standards, the MXN asynchronous low-voltage e-motor (IE3) developed to be modular, reliable, energy efficient and internationally certified, and a DGM MPM sensorless inverter.
Visitors got an up-close look at the two successful applications designed in partnership with Modula S.p.a. and I.DE S.r.l., for which Bonfiglioli has developed complete and tailor-made technical solutions.
The latest frontier in mobile collaborative robotics applications
