Doing More with Less
Running parallel to the increased adoption of electromechanical technology is a growing consideration for sustainability practices. While European manufacturers have embraced this trend, U.S.-based manufacturers have yet to recognize the long-term monetary benefits of it. Additionally, compliance regulations continue to be introduced in a variety of sectors within manufacturing and the processes will need to reflect those industry standards.
Electromechanical solutions can be more compact and use less components than hydraulic ones. By simply reducing the amount of space needed for a certain process, manufacturers can cut down on hazardous risks from unnecessary equipment and also eliminate unnecessary time maintaining those additional components. Electromechanical solutions operate only when needed – the power required for the task is the only power that’s being consumed. Hydraulic solutions require constant pressure from a pump, which means they may use more energy to complete the same task. Although some electromechanical solutions may be more expensive up front than their hydraulic counterparts, the lower long-term cost of ownership and the reduction of line-down repairs give electromechanical solutions an excellent return on investment.
A Premium on Precision
Not only are manufacturers incorporating sustainability practices into their processes, but they are also being asked to make more precise and tight-tolerance parts. Ball screw and planetary screws are the foundation of electromechanical actuators due to their high precision, accuracy, and mechanical efficiency. When paired with a servomotor, they operate as the work horse in electromechanical operations and are the catalyst in ensuring a reduced amount of scrap and an increased percentage of highly specified, usable products. Beyond the motors, sensors also play a critical role in electromechanical processes by delivering accurate, real-time process feedback. Sensor integration with electromechanical actuators is simple, because the information is sent directly to the servo drive and improves the accuracy and efficiency of the process. Monitoring and digesting that sensor data and translating it into actionable insights is becoming the norm in manufacturing, and those who do it well are at a competitive advantage.
The Human Touch
As linear motion processes continue to be automated, human interaction subsequently is redefined and reassigned. There is a dwindling skilled labor force that possesses the knowledge and expertise required to operate the more outdated equipment and as such, manufacturers are relying more on automation. Because of that labor gap, there is a demand for simple, automated process equipment that does not require advanced education to operate, particularly for a smaller factory owner. The “set it and forget” nature of newer linear motion solutions means that manufacturers are less exposed to the on-going labor force issues. These new electromechanical solutions can be integrated and implemented quickly into existing processes and often come with easy-to-use software that reduces onboarding time. The digital nature of electromechanical versus hydraulic solutions naturally plays well into the hands of younger workers, many of whom have been using smartphones, laptops, and tablets since they were young. This changing of the guard suggests that plant managers should empower their workers with the technology that they’re most familiar with and digitally automated processes are a clear representation of that.
The Future is in the Balance
It bears noting that while the case has been made on several fronts for the benefits and realities of a shift towards electromechanical for lower and medium force applications, there is, and there will always be, a need for hydraulic solutions in the highest force processes. Established solutions like large hydraulic presses are the manufacturing cornerstones in several industries, with some presses from the mid 1900s still in operation. Their longevity in those applications is due to their universal nature and reliability. It is up to each manufacturer to constantly evaluate operations and use available data to gauge performance. Optimal manufacturing is the right technology operating at peak performance. While hydraulics continue to play a role in that equation, electromechanical solutions are now the biggest driver in the technological advancement of linear motion.
About the author: Carter Paden is product manager at Bosch Rexroth.
