Binder Expands M8 Series of Connectors for Sensor and Automation Applications
Binder USA, LP, has expanded their M8 product portfolio with 12-pin M8 male panel-mount connectors with dip-soldered contacts. The new connectors are part of binder’s Series 768/718, which is designed for signal and data transmission applications, including: Industry 4.0 automation, sensor arrangements, and industrial cameras, as well as measurement and control technology.
The male and female panel-mount connectors are easy to install and can be screw-mounted at the front. They are available in different designs with or without a shielding plate. The housing is made of polyurethane (PUR) and has gold-plated crimp contacts that can be dip soldered. A nickel-plated, zinc-diecast threaded ring ensures a sturdy connection of the connectors designed for more than 100 mating cycles. The screw locking system of the connectors complies with DIN EN 61076-2-104.
