Cummins (CMI) recently announced that through its subsidiary Meritor, it has completed the acquisition of Siemens Commercial Vehicles business, a top supplier of high-performance electric drive systems for commercial vehicles. The acquired business will report through Cummins New Power business unit.
Rolling bearing life depends on the contact stresses that occur between the rolling elements and the raceways. Contact stresses are calculated from contact loads, which in turn depend on the external loads acting on the bearing and the precise internal geometry of the bearing.
Applied Flow Technology (AFT) has expanded their team with the hire of two new engineers and one software developer to join their pipe flow modeling team.
Between now and 2030, a state-of-the-art digital train control system from Siemens Mobility will be installed as an upgrade to the conventional train control system used by operator Hamburger Hochbahn (HOCHBAHN) on its U2 and U4 subway lines. The new technology, known as CBTC (communication-based train control), will allow trains to run at shorter intervals of only 100 seconds, which will put significantly more trains on the track in the future, thereby increasing capacity. In addition, CBTC also improves punctuality, reliability, and energy consumption.
Manufacturer-independent engineering tools, such as KISSsoft, basically offer users the opportunity to offer more flexibility in selecting suppliers and procuring components. On the other hand, in some cases there is no access to exclusive product data from the manufacturer in order to be able to perform the calculation with the greatest possible accuracy and reliability.
Parker Hannifin is releasing the new Parker Motion Controller range for the global industrial automation market. Intelligent, multi-axis Parker Motion Controllers combine machine logic, real-time motion control, advanced safety features and visualization in a completely scalable solution.
