Automation specialist B&R is using this year's PackExpo exhibition in Las Vegas to feature open solutions with Codian robot mechanics, now integrated and rebranded within B&R. The Codian portfolio of delta configurations, including class-leading hygienic models, is open to any control platform and can be incorporated into any machine configuration. B&R's Machine-Centric Robotics solution combines Codian mechanics and B&R controls to offer machine builders and manufacturers single-source robotics and automation for precise synchronization and ease of engineering – ideal when implementing highly flexible packaging solutions.
Mechanical motion components, though relatively small, contribute immensely to the safety of multiple systems like automobiles, manufacturing systems, elevators, water treatment facilities, etc. Motion components experience wear and tear over time caused by:
Friction as motion surfaces come into contact with adjacent components.
Corrosion due to exposure to chemicals, humidity, and corrosive gasses
Fatigue emanating from repetitive stress and strain.
Siemens Mobility and ÖBB (Austrian Federal Railways) are digitizing the Austrian rail network to further enhance the attractiveness of public transport. ÖBB is aiming to double the capacity of Austria’s entire rail system by 2040 to cope with increasing passenger numbers. This goal is now a bit closer: The most modern technology for railway operations – the digital European Train Control System ETCS – has now been implemented and commissioned on the 57-kilometer route between Linz and Vöcklabruck. The system controls distances between trains, as well as their direction and speed in real time. This enables the route to carry more passengers and freight, and ensures that the trains run more reliably, punctually, and safely.
Digital Metrology Solutions, provider of measurement software, consulting, and training, has introduced TraceBoss+ (TraceBoss Plus) software, integrating surface texture and crosshatch measurement in a single package.
Siemens Digital Industries Software recently announced that Tianneng Battery Group Co., Ltd. has selected the Siemens Xcelerator portfolio of industry software to help it drive innovation and enable digital manufacturing in new battery production.
A new version of the MESYS shaft and rolling bearing analysis software including new functionality is available. The bearing analysis software allows the calculation of the load distribution within the bearing and bearing life according to ISO/TS 16281 and it is integrated in a shaft system calculation with additional possibilities like modal analysis, strength calculation for shafts and interfaces to gear calculations. Currently the software is used by customers in 31 countries on 4 continents. The new version is now available.
The prediction and prevention of catastrophic failures and unplanned downtime has vastly improved areas like mining, energy, off-highway, and other industrial segments for MRO departments across manufacturing thanks to cutting-edge condition monitoring technology and predictive maintenance.
KISSsoft helped AGH Racing students in Poland develop steering column gears in the RTC7.0 race car powered by an internal combustion engine. Then they used the software to develop a gearbox for their new electric AWD drivetrain in the upcoming RTE3.0 car. Most importantly, they could optimize the micro geometry of the gears and analyze the influence of different factors on the durability of the gear tooth. KISSsoft made it easier to apply quick changes in the project, as it adapts other tooth geometry to the ones they were working on.
Technical sales personnel use intelligent features to select suitable motor-gearbox combinations and run calculations based on customer-specific operating data. This provides obvious added value for the customer. Service lives, safeties, and expected loads can all be determined in a short time. Maintenance of the underlying database and the use of simulation tools make it possible to quickly and easily perform technical calculations without having to rely on a central calculation department. In less than a minute, the customer is provided with a data sheet which includes reliable statements about the gearbox based on these technical calculations.
