With the P-725.xCDE1S focus scanner and the U-781 PILine XY stage system, PI completes its range of positioning systems for fluorescence microscopy applications. The dynamic focus scanner is offered as a complete package including controller and allows travel ranges up to 400 µm. The U-781 XY stage system with controller and joystick is mechanically compatible with inverted microscopes of leading manufacturers and offers interfaces to common microscopy software tools such as µ-Manager, MatLab, LabView, Python, and Nikon NIS Elements—all at an attractive price/performance ratio.
Engineered with precision and versatility in mind, the MTB 105 is specifically designed to integrate into multi-axis medium- to large-sized Cartesian Gantry systems, providing robust support for medium to high payloads. Its fully enclosed design ensures reliability even in contaminant-prone environments, making it an ideal choice for a wide range of applications. Precision extrusions for each aluminum actuator body ensure all sides and bottom surfaces are flat and perpendicular giving accurate installations.
Ruland Manufacturing now offers bellows and double disc couplings with bore sizes up to 1-3/4 in or 45 mm for use in systems with torque up to 1,4000 in-lbs. (158 Nm). High torque applications commonly found in precision semiconductor, solar, conveyor, and factory automation applications often use these shaft sizes. Ruland disc and bellows couplings accommodate all forms of misalignment, are zero-backlash, and have a balanced design for reduced vibration at speeds up to 10,000 rpm.
In KISSsoft, 97 (yes, ninety-seven!) plastics are available for calculation of cylindrical and crossed axis helical gears. The materials range from unreinforced POMs and PAs to high performance reinforced and internally lubricated materials.
It’s common to hear “surface roughness” described as a number that can be measured on a gage. But describing surface texture with a number is a lot like describing a concert in decibels: loudness is just part of the story. A rock band, an orchestra, and a chainsaw can all produce 100 decibels, but the full picture is much more complex and interesting.
SKF has extended its Microlog Analyzer family of data collection devices with a new model that offers faster measurement collection and greater diagnostic power.
KISSsoft offers the calculation of geometry and contact stresses of Hirth couplings. Hirth couplings allow for thetransmission of high torque between shafts. In KISSsoft, users can select a standard Hirth coupling offered by Voith GmbH & Co. KGaA or enter their own custom geometry for the calculation.
EV developers are finding a competitive edge through efficiency gains not only in new battery pack technology and electronic components, but also through new developments in electric machines.
