Third-quarter earnings confirmed
the worst-case scenario — plunging oil prices are whacking almost the entire industrial sector. The theme is hardly new, as the pattern of our headlines has revealed over the past fifteen or so months:
Guy Gendron, certified bearing specialist and technical sales representative at Timken Canada L.P. explains how he used his bearing expertise to increase a customer’s productivity.
finished products.
End market conditions for the power transmission industry continue to worsen. With the Euro down 13% year to date and U.S. oil production surging we are seeing increasing headwinds, if not storm clouds, for the sector.
The first thing you see when you walk into Winzeler Gear is a pretty face. No, scratch that — the face is beautiful. Streamlined with chiseled cheek bones, delicate yet bold and strong, a half dozen photos of the feminine face line the building’s entranceway, enclosed tastefully in simple black picture frames, beckoning you to come further in with its pleasant warmth, repelling you to turn and leave with its foreign presence in such a location.
