The automotive industry is reshaping faster than ever before. Technology advancements are redefining transportation from traditional mechanics to complex sustainable, entertaining, and connected mobility enabled by electronics and software. To stay relevant in this fast-changing market, automakers must revisit how they approach all aspects of product design, development, and manufacturing.
Global industrial and automotive supplier Schaeffler was honored by the Bearing Specialists Association (BSA) with the 2021 “Bearing Manufacturer Excellence of Innovation in Product Design Award” for its breakthrough OPTIME condition monitoring device.
Stainless steel ASK Couplings from Miki Pulley feature a unique “sliced” body structure making them an effective low-cost corrosion resistant solution that can accommodate many types of misalignments. The stainless-steel design makes them ideal for use in food and chemical applications.
NORD’s nsd tupH sealed surface treatment is available as an option with a variety of their modular products and provides an easy to clean surface suited for harsh processing and manufacturing environments.
SKF has developed a new range of adjustable chocks with higher load capacity and an increased adjustment range. The chocks can be used in many industries, including food and beverage, pulp and paper, rail, marine, offshore, agriculture and power generation. They are typically found in equipment such as gas, diesel and LNG engines, generators, compressors, electric motors and gearboxes.
Manufacturing is facing constant challenges stemming from labor shortages and disrupted supply chains to productivity declines and the high replacement and maintenance costs of legacy equipment. Trends today include equipment upgrades, e-commerce, a push for more robotics and automation and faster software and IIoT solutions.
