Commercial garage doors range in many sizes and configurations requiring a “just right” model and size brake for reliable automatic operation. Depending on the design and size of the overhead door and placement of the brake, a variety of brake models and sizes offer solutions from the Miki Pulley brake lineup.
Racaw Ltd., a designer and manufacturer of precision positioning components and systems, required reliable shaft couplings for use on its lines of linear and rotary positioning stages. The stages allow precise linear and rotary positioning of objects via a stepping or servo motor with rotary encoder control. Huco Oldham couplings were selected because they met Racaw’s torque capacity range, zero backlash, auditable noise and vibration levels, lengthy predicted service life and availability requirements.
The Power Transmission Distributors Association (PTDA), the leading association for the industrial power transmission/motion control (PT/MC) distribution channel, welcomes a new distributor member: Nelson Electric Motors (Opelika, Ala.)
MagnaShear motor brakes, which provide a secure, no-maintenance, no-adjustment, holding brake solution for mining conveyor applications will be featured at MinEXCHANGE Booth #2720.
Timken Utilizes LK Metrology for Bearing Inspection and Analysis
January 9, 2023
The Dudley, UK factory of The Timken Company supplies the engineered bearings it manufactures into a multitude of industries including mining, food and beverage, pulp and paper, cement, marine, and wastewater. Recently there has been a significant increase in demand for larger bearings up to 1,200 mm in diameter for use in the construction of wind turbines, which promises exponential growth in the coming years as countries across the globe work towards meeting their green energy targets.
As of January 2023, Arkos Field Services, acquired by Burckhardt Compression in 2019, is integrated with Burckhardt Compression (US) Inc. Customers benefit from combined knowledge, expertise and unrivalled solutions for reciprocating compressors and other equipment from one provider. The integration of the two brands streamlines business processes to provide easy access and a solutions-driven customer experience.
David Brown Santasalo (DBS) was delighted to recently welcome valued customer, Breedon Cement’s new intake of apprentices, reliability engineers and their mentors to their Park Works, Huddersfield, UK facility for a day of training delivered by DBS’ Development Director, Mike Field.
The Ogura MCNB-HS Series power-off spring applied brakes have oversized bores to allow wires to pass through the shaft’s hollow bore. They accommodate encoders, cables, hoses, shafts, and tools. The ratio of the brake’s field core diameter to outer diameter is leading the industry.
Corrosion under insulation (CUI) is a longtime plague of petrochemical, refinery, and marine environments. The problem is so bad that an estimated 40-60 percent of piping maintenance costs in the oil and gas industry stem from CUI-related expenses. Even worse, undetected CUI on pipes carrying hazardous liquids may lead to leaks and potential explosions. To tackle this dangerous and costly problem, Cortec Corporation has developed CorroLogic CUI Inhibitor Injection, a new Vapor phase Corrosion Inhibitor technology that simplifies protection for insulated pipes reaching a high range of temperatures.
