At the recently held annual meeting of the Bearing Specialists Association, there was a lot of talk about online sales channels and how Internet retailers are changing the way industrial products are researched, sourced and purchased.
For either brand-new motors or those already in service, "best practices" means that informed technicians can make use of the latest diagnostic techniques (vibration analysis, thermography, shaft-voltage testing, etc.) to prevent electrical bearing damage -- either at the very beginning or very quickly thereafter. If done correctly, the work need only be done once.
The following news items offer the latest on lubrication and seal technology in the power transmission market. From bearing greases to high-performance seals, these products will help extend the service life and manufacturing capabilities for a wide range of industrial sectors.
Seems simple enough doesn't it? It is most decidedly not. Indeed, one can make the case that--aside from uppermost management (or ownership)-- no one else in a heavy/high-tech manufacturing concern has more ownership of the company's everyday needs and necessities than the purchasing department.
