Seems simple enough doesn't it? It is most decidedly not. Indeed, one can make the case that--aside from uppermost management (or ownership)-- no one else in a heavy/high-tech manufacturing concern has more ownership of the company's everyday needs and necessities than the purchasing department.
Recently I had a disturbing conversation with a colleague here at the office. During the conversation, it became clear to me that my co-worker -- a really
intelligent guy whom I respect a lot -- had no idea how even the most simple electric motor works.
This article describes a series of tests that can be performed by the average user, with little experience, and without sophisticated measuring instruments, to quickly determine the most important performance characteristics of linear motion systems.
For the most accurate measurements,
miniature and instrument ball bearing
dimensions should be measured with a
calibrated air gauge. A good second option is a calibrated optical comparator. On occasion, it may be necessary to use a calibrated, hand-held micrometer to double-check a measurement or for simple verification while working in the field.
