This article is Part III in a series of articles on speed rating of bearings. Part I appeared in the September 2022 issue ("Ball Bearing Limiting Speeds"), and Part II appeared in the October 2022 issue ("Ball Bearing Thermal Speed Rating"). Bearings with Norm examines the latest in bearing technology and design.
Corrosion under insulation (CUI) is a longtime plague of petrochemical, refinery, and marine environments. The problem is so bad that an estimated 40-60 percent of piping maintenance costs in the oil and gas industry stem from CUI-related expenses. Even worse, undetected CUI on pipes carrying hazardous liquids may lead to leaks and potential explosions. To tackle this dangerous and costly problem, Cortec Corporation has developed CorroLogic CUI Inhibitor Injection, a new Vapor phase Corrosion Inhibitor technology that simplifies protection for insulated pipes reaching a high range of temperatures.
Velo3D, Inc. has announced Hermeus, a company developing hypersonic aircraft for defense and commercial applications, has acquired an original Sapphire and a large-format Sapphire XC that is designed for high-volume production. The printers, both of which will be calibrated for Inconel 718, will be used to build parts for Hermeus’ Chimera engine and Quarterhorse aircraft.
Robotic applications in manufacturing need precise movement and positioning in manufacturing operations from teach pendant programming through full, automated production with exact sequential motion and timed positioning. Miki Pulley BXR Brakes apply holding torque after the motor joint stops and provides dynamic braking in the event of an emergency such as a power interruption.
Siemens Digital has added features and updates for Simcenter SPEED, Simcenter Motorsolve and Simcenter MAGNET 2022.1 to improve accuracy, flexibility and connectivity. This 2022.1 update makes Simcenter SPEED and Simcenter Motorsolve more accurate and better integrated to Simcenter STAR-CCM+.
SEGULA Technologies and British scale up Senseye, specialized in predictive maintenance based on artificial intelligence, have announced the signing of a partnership.
SMT's latest webinar "MASTA Support - Tips, Tricks and FAQ" will take place May 4, 2022. The SMT customer support team receive queries covering all areas of MASTA, with industry 'hot topics' inevitably arising. In this webinar, SMT engineers focus on answering some of the queries that frequently make it into their support inbox.
