We are pleased to present our first annual Engineering Showcase, a celebration of some of the leading products and companies in mechanical power transmission. In the pages that follow, you’ll find examples of engineering excellence and technological know-how in the field of gears, drives, couplings, machine parts and other mechanical components.
This paper will look at the solutions that current drive and motor technology can offer in not only improving tension control but also solving several other issues that are inherent to systems with high ratio gearing.
Even when the critical components of industrial power transmission gear drive systems are properly designed, specified
and manufactured consistent with application requirements, performance
problems can develop over time and failure may follow.
Most manufacturers of shaft-mounted speed reducers offer torque arms for their products. However, in some situations, a machine designer may be required to design his own.
