Finding picture books for kids old enough to appreciate them can be a daunting task. There are, of course, the usual suspects--celebs, athletes, boy bands, girl bands, and so on, but not much of substance. That's where David Janosz Jr. enters the picture.
After a brief introduction to the importance of gear pumps in internal combustion engines, as well as in the most diverse hydraulic applications, a calculation method was applied that allows for sizing with considerably higher delivery rates. Upon identifying and analyzing a traditional pump, along with two construction solutions of asymmetric gear pumps, we then compared their related performances.
We are pleased to present our first annual Engineering Showcase, a celebration of some of the leading products and companies in mechanical power transmission. In the pages that follow, you’ll find examples of engineering excellence and technological know-how in the field of gears, drives, couplings, machine parts and other mechanical components.
