In an industrial application, equipment
uptime is vital for on-time performance and profitability. The rotating members of industrial machines are subject to the highest degree of wear and are more susceptible to failure than non-moving parts. Bearing surfaces are the most critical and often the most expensive portion of the rotary assembly; it is
imperative to protect these components. The primary protector of these components is the industrial seal.
Most manufacturers of shaft-mounted speed reducers offer torque arms for their products. However, in some situations, a machine designer may be required to design his own.
Rolling element or sleeve bearings often are required to operate under extreme conditions. In these instances, it is more important than ever to follow proper lubrication selection and maintenance procedures to maximize effective life and efficient performance.
