Sustainability is becoming one of the most important aspects within the power transmission business. Users demand low-maintenance drive systems with as little disruption as possible, and expect lifetimes of more than 10,000 hours. Approximately 40 percent of long-term gearbox leakages can be traced back to poor interaction between the radial shaft seal (RSS) and the lubricant. Thus, it becomes essential to analyze the tribological system as a whole, which includes the gear oil, seal grease (if required), elastomer material and design, and the shaft.
In this study the mechanical shear degradation of lithium-thickened grease was evaluated using an in-house-developed aging rig and a commercial rheometer. It was found that this grease loses its original consistency during aging and shows a two-phase aging behavior. In the first phase, primarily reorientation and breakage of the thickener network take place, resulting in a progressive drop in the grease's rheological properties. After this, the aging is dominated by the breakage of smaller fiber fragments and the grease degrades at a much slower rate.
Understanding proper bearing lubrication procedures is critical to ensuring long-term, trouble-free performance. Klüber Lubrication has prepared this explanation as a general guide.
