Gear drives are fundamental in most processing operations, connecting the prime mover to the driven equipment and ensuring that the system has enough torque to effectively move product. Correctly specifying and selecting the proper gear drives for critical applications leads to reliability, greater uptime, and profitability.
The new KISSsoft release 2024 is coming soon! This April will bring you the new system module KISSdesign, accelerating the calculation of complex drive trains and replacing the previous KISSsys software.
Modern spindle applications of rolling bearings require very high speeds and very high loads, often combined with poor lubrication conditions and/or high solid contamination. Examples of these applications are high-speed and high-cutting rate machine tools, where rolling bearings need to survive very though conditions. Rolling bearings in high speed and high load conditions might suffer from poor lubrication and potentially surface distress and adhesive wear.
Solid Edge is a portfolio of affordable, easy-to-use software tools that address all aspects of the product development process. Solid Edge combines the speed and simplicity of direct modeling with the flexibility and control of parametric design – made possible with synchronous technology. The following Q&A discusses Solid Edge 2024 with Dan Staples, vice president, mainstream engineering, Siemens Digital Industries Software.
A good 20 years have passed since the web-based calculation software eAssistant saw the light of day in the digital world. The software is probably the oldest commercial online solution for the design, recalculation and optimization of machine elements such as shafts, bearings, shaft-hub connections, gears, bolted joints, springs, etc. The calculations are based on internationally accepted standards and guidelines as well as technical literature.
Gearmotors are used in processes to produce, manufacture, convey, package and store products used every day and are used frequently in small packaging applications due to their compact size. These units need care via preventive maintenance just like any asset used on a production site.
