The engineering community is fascinated with big, shiny, yellow machines. Walk into any manufacturing facility around the globe and you’ll find guests huddled around the biggest, loudest, and most intimidating equipment on the shop floor. These large machines must play by the same rules as everybody else—they need to reduce energy consumption, lower plant costs, and increase productivity. Many power transmission component suppliers are tasked with optimizing this equipment.
2022 marks the 20th Anniversary of SMT’s focus on providing the tools and knowledge to drive engineering innovation in gearbox system analysis. With this historic company anniversary, the company has announced the return of the North America User Forum.
Torque Transducers and Test Machinery experience extreme demands including high torque loads and high operating speeds which cause stress on connected components. To assure these systems generate accurate test data when experiencing these conditions, system designers specify CD Couplings from Zero-Max.
Siemens Digital has added features and updates for Simcenter SPEED, Simcenter Motorsolve and Simcenter MAGNET 2022.1 to improve accuracy, flexibility and connectivity. This 2022.1 update makes Simcenter SPEED and Simcenter Motorsolve more accurate and better integrated to Simcenter STAR-CCM+.
SEGULA Technologies and British scale up Senseye, specialized in predictive maintenance based on artificial intelligence, have announced the signing of a partnership.
SMT's latest webinar "MASTA Support - Tips, Tricks and FAQ" will take place May 4, 2022. The SMT customer support team receive queries covering all areas of MASTA, with industry 'hot topics' inevitably arising. In this webinar, SMT engineers focus on answering some of the queries that frequently make it into their support inbox.
Considering the local flank parameters, such as pressure or transmission error, a significant influence of the load-dependent center distance can be observed. With the FVA-Workbench, the load-dependent center distance is always considered.
