In its largest order to date, Danish wind turbine test specialist R&D Test Systems will develop the 30 MW powertrain and gearbox test bench for ZF Wind Power’s future “Test & Prototype Center” at Lommel, Belgium. Capable of simulating the multiplicity of wind loads that a nacelle powertrain might experience in its lifetime, the test rig, to be delivered in 2024, will help improve product reliability and shorten time to market.
Stober Relies on FVA Workbench for Drive Verification
September 30, 2022
Stöber Antriebstechnik GmbH + Co. KG rely on the FVA-Workbench for dimensioning and verification of their drives. The calculation and simulation software allows Stöber engineers to develop their innovative gear unit solutions more quickly and efficiently. The result: higher quality products.
MiTek brings over 30 years of contacts in steel and aluminum
September 7, 2022
Atlanta Gear Works has announced a new working agreement with Jim McClain, general manager of McClain Industrial Technologies, Inc., DBA MiTek, a manufacturers’ rep that will help the gearbox repair and manufacturing firm spread its 34-year reputation in pulp and paper to the steel and aluminum industries.
Axially space-saving, economical, IP65-compliant and designed for high radial and axial forces at the output: The Neugart WPLHE combines all the advantages of the successful PLHE, as a right-angle variant.
