MiTek brings over 30 years of contacts in steel and aluminum
September 7, 2022
Atlanta Gear Works has announced a new working agreement with Jim McClain, general manager of McClain Industrial Technologies, Inc., DBA MiTek, a manufacturers’ rep that will help the gearbox repair and manufacturing firm spread its 34-year reputation in pulp and paper to the steel and aluminum industries.
Axially space-saving, economical, IP65-compliant and designed for high radial and axial forces at the output: The Neugart WPLHE combines all the advantages of the successful PLHE, as a right-angle variant.
JIE USA has released a 3D CAD gearbox and gearmotor configurator to help engineers choose motors and drives on-demand. The online tool enables engineers to identify the correct product for their design or application based on custom parameters and deliver the CAD model or PDF datasheet they need to do their job efficiently.
