Circular pitch gives me the size of the teeth in my mind, but diametral pitch does not. What is the purpose of the diametral pitch concept? Does it merely avoid pi in calculation?
Beginning with a brief summary and update of the latest advances in the calculation methods for worm gears, the author then presents the detailed approach to worm gear geometry found in the revised ISO TR 10828. With that information, and by presenting examples, these new methods are explained, as are their possibilities for addressing the geometrical particularities of worm gears and their impact upon the behavior and load capacity of a gearset under working conditions based on ISO TR 14521 — Methods B and C. The author also highlights the new possibilities offered on that basis for the further evolution of load capacity calculation of a worm gearset based on load and contact pressure distribution.
Following is a presentation of a gear design based upon a theoretically perfect gear technology, for which an overview is offered for consideration. What follows is a report on the design's testing and subsequent manufacture of a hypoid gear pair for a 1999 Ford Mustang.
For the most accurate measurements,
miniature and instrument ball bearing
dimensions should be measured with a
calibrated air gauge. A good second option is a calibrated optical comparator. On occasion, it may be necessary to use a calibrated, hand-held micrometer to double-check a measurement or for simple verification while working in the field.
