Does the definition of specific sliding mean the same between ISO 21771:2007 and AGMA 917-B97? In ISO, specific sliding is the ratio of the sliding speed to the speed of a transverse profile in the direction of the tangent to the profile. In AGMA, specific sliding is ratio of gear tooth sliding velocity to its rolling velocity.
Asymmetric tooth gears and their rating are not described by existing gear design standards. Presented is a rating approach for asymmetric tooth gears by their bending and contact stress levels, in comparison with symmetric tooth gears, whose rating are defined by standards. This approach applies finite element analysis (FEA) for bending stress definition and the Hertzian equation for contact stress definition. It defines equivalency factors for
practical asymmetric tooth gear design and rating. This paper illustrates the rating of asymmetric tooth gears with
numerical examples.
Dale Renner, CBS and sales representative at Bearing Headquarters Co., explains how his bearing expertise
helped solve a customer’s problem
and saved significant downtime and
cost.
Is there a gear software package out there that will calculate the design of spur, helical, worm, and planetary gearsets? Also, we would like a program that calculates stresses and material selection. Finally, we would like to have the program calculate bearings loads, too. Thank you for your help.
Today’s competitive industrial gear marketplace demands products with excellent reliability, high capacity and low noise. Surface-hardened, ground tooth gearing predominates, but the legacy tooth forms handicap further improvements in capacity and noise generation. Vehicle and aircraft equipment use tooth forms not found in the standard tables to achieve better performance — with little or no increase in cost. This paper will propose adopting these high-contact ratio forms to industrial use.
