Tooth contact analysis is an integral part of the gear design process. With the help of these simulation tools, it is possible to calculate the excitation caused by a tooth contact (Ref. 1). Usually, the load-free transmission error or the total transmission error under load is used for this purpose. However, the calculation with the tooth contact analysis ZAKO3D allows only a quasi-static consideration of the excitation. To better evaluate the behavior in the overall system, it is therefore necessary to perform a dynamics simulation. However, the main disadvantage of such dynamics simulations is the much longer computing time compared to quasi-static tooth contact analyses due to the high computational effort.
Mechanical engineering theory, design and practice come into play for NYCU Vulpes Racing Team
April 6, 2023
Applied Flow Technology (AFT) has expanded their team with the hire of two new engineers and one software developer to join their pipe flow modeling team.
Siemens Digital has added features and updates for Simcenter SPEED, Simcenter Motorsolve and Simcenter MAGNET 2022.1 to improve accuracy, flexibility and connectivity. This 2022.1 update makes Simcenter SPEED and Simcenter Motorsolve more accurate and better integrated to Simcenter STAR-CCM+.
