slow speed operation.
In order to analyze the different gear
oils suitable for the lubrication of wind turbine gearboxes, five fully formulated ISO VG 320 gear oils were selected. In between the selected gear oils, four PAO base oils can be found: PAOR, PAOM, PAOC and PAOX. A mineral-based oil (MINR) was also included as reference.
conveying system on the varnishing
line for a manufacturer of high-end
kitchen cabinets were leaking. Oil was
dripping on the cabinet parts — ruining
the finish. Why were half of the
gearboxes leaking?
Standard carburizing steel 18CrNiMo7-6 is often used when high hardenability is required, but due to its highly fluctuating price, there has always been an incentive to develop Ni-free steel grades. The 23MnCrMo5-5-2 — or Jomasco 23mod — has been developed for
this purpose. But to ensure smooth substitution within existing production lines, a number of points must be addressed: first, checking the response to carburizing treatments;
and second, having similar mechanical properties with identical tooth root bending performance on gears. The latter is the purpose of this paper.
This paper presents a method for the acoustic analysis of electric motors in noisy industrial environments. Acoustic
signals were measured via acoustic camera 48-microphone array, which has the capability to localize a sound
(or sounds) source and, in turn, separate those sounds from intrusive background noise. These acoustic analysis results are then compared with vibration measurements; vibration monitoring is a well-known and established technique used in condition monitoring, and in this work vibration measurements were used as a reference signal for assessment of the value of the acoustic measurements. Vibration signals were measured by piezoelectric accelerometers. Two induction motor cases were examined — a healthy motor case, and a combination of static eccentricity with soft foot case. As shown, acoustic analysis appears to be a valuable technique for condition
monitoring of electric motors — particularly in noisy industrial environments.
When a power transmission component fails, it can adversely affect the performance of the assembly, often
making the machine inoperable. Such failures can not only harm the reputation of the manufacturer, but can lead to litigation, recalls and delays in delivery due to quality concerns. Some failures can even result in bodily injury or
death. Understanding why a part failed is critical to preventing similar failures from reoccurring. In the study of a failed part, the analyst must consider a broad range of possibilities for the failure. Although some failures can be
attributed to a single primary cause, it is common for multiple secondary factors to contribute. The failure analyst must evaluate all of the evidence available to prepare a hypothesis about the causes of failure.
Asymmetric tooth gears and their rating are not described by existing gear design standards. Presented is a rating approach for asymmetric tooth gears by their bending and contact stress levels, in comparison with symmetric tooth gears, whose rating are defined by standards. This approach applies finite element analysis (FEA) for bending stress definition and the Hertzian equation for contact stress definition. It defines equivalency factors for
practical asymmetric tooth gear design and rating. This paper illustrates the rating of asymmetric tooth gears with
numerical examples.
During the past 10 years, the PM industry has put a lot of focus on how to make powder metal gears for automotive transmissions a reality. To reach this goal, several hurdles had to be overcome, such as fatigue data generation on gears, verification of calculation methods, production technology, materials development, heat treatment recipes, design development, and cost studies.
All of these advancements will be discussed, and a number of vehicles with powder metal gears in their
transmissions will be presented. How the transmissions have been redesigned in order to achieve the required stress levels while minimizing weight and inertia, thus increasing efficiency, will also be discussed.
