Implementing a power-on-demand concept based on variable speed drives allows for energy saving in any application
that involves pumps or hydraulic systems. And when used in combination with an intelligent wiring and communication system, relevant machine data can also be easily recorded
- the basis for comprehensive power management.
Beginning with this initial installment , and with the gracious permission of ABB/Baldor Electric, we are
pleased to announce the beginning of a new series -- Baldor Basics: Motors. This is a collection of basicsdriven,
motor-intensive articles authored by former Baldor engineer Edward Cowern, PE, a respected
name by many in the electric motor industry. During his tenure at Baldor, Cowern - now enjoying his
retirement - was tasked with producing a number of motor- and basics-related tutorials, primarily in
response to a steady flow of customer questions regarding motors. Today's customers continue to ask
questions and seek answers to address their various motor-related issues. As with Cowern's original
introduction to the series, we hope you find these articles useful and would appreciate any comments or
thoughts you might have for future improvements, corrections or topics.
If you’re an electrical engineer
you know how an electric motor works; if
you aren’t, it can be extremely
confusing. Therefore, here’s the simplified explanation (or the “how
an electric motor works for dummies” version) of how a four-pole, three-phase
AC induction motor works in a car.
slow speed operation.
In order to analyze the different gear
oils suitable for the lubrication of wind turbine gearboxes, five fully formulated ISO VG 320 gear oils were selected. In between the selected gear oils, four PAO base oils can be found: PAOR, PAOM, PAOC and PAOX. A mineral-based oil (MINR) was also included as reference.
conveying system on the varnishing
line for a manufacturer of high-end
kitchen cabinets were leaking. Oil was
dripping on the cabinet parts — ruining
the finish. Why were half of the
gearboxes leaking?
Standard carburizing steel 18CrNiMo7-6 is often used when high hardenability is required, but due to its highly fluctuating price, there has always been an incentive to develop Ni-free steel grades. The 23MnCrMo5-5-2 — or Jomasco 23mod — has been developed for
this purpose. But to ensure smooth substitution within existing production lines, a number of points must be addressed: first, checking the response to carburizing treatments;
and second, having similar mechanical properties with identical tooth root bending performance on gears. The latter is the purpose of this paper.
