Electric drives often need to operate under high voltages up to 800 V to provide more power and higher speeds. However, the risk of partial discharges increases at these voltages. In combination with high operating temperatures, these can locally damage the insulation and lead to machine failure. However, a good impregnation ensures not only electric insulation but also copper bonding, to mechanically strengthen the electric motor, and air gap filling, to allow a better heat transfer.
NTN Bearing Corporation of America is pleased to announce the release of its latest product offering, the SNC plummer block. The SNC blocks are yet another heavy-duty mounted unit designed specifically to accommodate the rigors of applications within construction, mining, and other large-scale equipment applications.
Kollmorgen has announced the new AKD2G 24A drive. Designed for applications in precision multi-axis servo systems, the new single-cable optimized drive builds upon the strengths of the AKD2G portfolio including upgraded safety features, SD card backup and a graphical display with higher amperage to support more applications with higher power requirements such as conveyors and vertical lifting applications.
With the introduction of their first IE5+ permanent magnet synchronous motor in 2021, Nord Drivesystems delivered a new standard of energy efficiency, variant reduction, and reduced operating costs. This Size 71 TENV smooth surface design has paved the way for additions to the IE5+ product family including ventilated designs and larger frame sizes to expand performance and versatility even further. These motors are UL/CSA certified and can be utilized across a wide range of industries and applications.
Regal Rexnord Corporation introduces its new Rexnord 6997 Series MatTop Chain. The chain offers an innovative new solution for the increasing performance demands of Pasteurizer, Warmer and Cooler tunnel applications.
In several working demonstrations, KUKA Robotics will showcase various innovative automation solutions for specific handling applications during Pack Expo 2023 in booth C-3236 Central Hall.
A new version of the MESYS shaft and rolling bearing analysis software including new functionality is available. The bearing analysis software allows the calculation of the load distribution within the bearing and bearing life according to ISO/TS 16281 and it is integrated in a shaft system calculation with additional possibilities like modal analysis, strength calculation for shafts and interfaces to gear calculations. Currently the software is used by customers in 31 countries on 4 continents. The new version is now available.
Rollon has introduced its TLS Series of telescoping linear actuators. The new series is designed to maximize productivity for applications where space is limited — especially for applications with minimal vertical clearance, such as between the machine and ceiling, or horizontally between machines.
