Automation specialist B&R is using this year's PackExpo exhibition in Las Vegas to feature open solutions with Codian robot mechanics, now integrated and rebranded within B&R. The Codian portfolio of delta configurations, including class-leading hygienic models, is open to any control platform and can be incorporated into any machine configuration. B&R's Machine-Centric Robotics solution combines Codian mechanics and B&R controls to offer machine builders and manufacturers single-source robotics and automation for precise synchronization and ease of engineering – ideal when implementing highly flexible packaging solutions.
Conveying parcel delivery with no system downtime is accomplished with speed and accuracy using Miki Pulley CSZ Clutches. Conveyors continuously operate via servomotor power by way of a V-belt. The system automatically switches on/off as programmed when engaged by the CSZ Clutches.
ZF has developed an electric motor which does not require magnets. In contrast to the magnet-free concepts of so-called separately excited synchronous motors (SESM) already available today, ZF’s I2SM (In-Rotor Inductive-Excited Synchronous Motor) transmits the energy for the magnetic field via an inductive exciter inside the rotor shaft. This makes the motor uniquely compact with maximum power and torque density.
With the SINAMICS S210 next generation servo drive system, comprising a digitally native drive with wide range of corresponding motors and gearboxes, Siemens brings a new level of high-dynamic, motion control in mid-range operation to stand-alone and multi-axis machines. This next generation servo drive system introduces a new level of safety and security to discontinuous motion control in the mid-range segment, as well as moving, processing and positioning functions on a wide assortment of packaging, printing, labeling, pick-and-place, stacking, assembly, chip sorting and filling machines, with a special emphasis on food-and-beverage and pharmaceutical applications, owing to the availability of stainless-steel motor and planetary gearbox options.
Heidenhain Corporation announces its participation in the upcoming NAEC (National Association of Elevator Contractors) 2023 Convention & Exposition. Connecting professionals from all over the elevator industry, NAEC will take place from September 10-13 at the Reno-Sparks Convention Center, Nevada.
In lithium-ion batteries, higher energy density increases the risk of thermal runaway. As a preventive measure, Freudenberg Sealing Technologies has developed thermal barriers that help to slow down thermal runaway by increasing resistance to propagation. The new 3D thermal barriers can be used at various positions within the battery and have already proven reliable in their initial series productions.
Digital Metrology Solutions, provider of measurement software, consulting, and training, has introduced TraceBoss+ (TraceBoss Plus) software, integrating surface texture and crosshatch measurement in a single package.
