Bodines New Motors Equipped with Interior Encoders June 7, 2007 The Incodermotor from Bodine Electric is a selection of permanent magnet DC and brushless DC motors and gearmotors that are equipped with...Read More
Gearmotors Built for High Torque Applications June 6, 2007 The AKM gearmotors set from Heason Technologies combines the torque density from the company's line of servomotors with its planetary...Read More
Applied Motions Stepper Drive Engineered for the OEM Market June 5, 2007 The ST10-S from Applied Motion delivers up to 10.0 A with 24-80 VDC input and can be controlled by a step and direction input or by a hos...Read More
Fairloc-Bellows, Neo-Flex and Shaft Couplings June 5, 2007 Fastening rotating components to shafts has become easier with Fairloc® Components. The patented system offers several features including...Read More
BWCs Linear Actuator Offered in Five Standard Lengths June 4, 2007 Bishop-Wisecarver's heavy duty linear actuator line, the SRX-150 is now available in five standard lengths. According to the company...Read More
NKE Introduces New Ball Bearings May 31, 2007 NKE introduced its new range of single row deep groove ball bearings. The new NKE POP range of single row deep groove ball bearings o...Read More
SKFs Spring-Load Ball Transfer Self-Adjust in Load Transfer Applications May 31, 2007 SKF 's "Hevi-Load" spring-loaded ball transfer unit for load-transfer application are engineered to reduce damage caused by shock loa...Read More
Beldens Corrosion-Resistant Universal Joints Suitable for Packaging Industry May 30, 2007 Belden introduces corrosion-resistant universal joints and drive shaft assemblies for the packaging and conveying industry. Accordin...Read More
Zero-Max's Newest Couplings Designed for Servo Application with High Reverse Load and Precise Positioning May 30, 2007 The next generation of ServoClass® couplings has been introduced by Zero-Max. According to the company's press release, the new c...Read More
Danfoss' New VLT Drive Handles Extended Motor Control Requirement May 30, 2007 Danfoss Drives' VLT® AutomationDrive variable frequency drives are now available in the 75-100 HP power range at 380-480/500 VAC. T...Read More
