Belt Tensioners and Chain Tensioners-Zetasassi July 12, 2007 QTC's Econobelt line includes over 330 Zetasassi belt and chain tensioners which improve performance by keeping constant tension. The...Read More
Big Kaiser's Boring Tools Allows Users to Make Incremental Adjustments July 11, 2007 BIG Kaiser Precision Tooling Inc. introduces a patent-pending new series of Kaiser boring tools. The new series has adjusting resolu...Read More
House Positioning System at AACC Meeting/Clinical Lab Expo July 10, 2007 Parker Hannifin's PROmech series of linear actuators come completely assembled and tested and include linear bearings, drive screws, ...Read More
Sick Stegmann's Programmable Encoders Designed for Miniaturized Applications July 10, 2007 Sick Stegmann Inc. introduced the DiCoder CKS 36 programmable motor feedback system. The user-programmable DiCoder CKS36 provides r...Read More
Helical Gears & Ground Helical Gears, Helical Gear July 10, 2007 QTC offers all types of Helical Gears and Ground Helical Gears. Quality Transmission Co. offers over 230 standard Helical Gear options fo...Read More
Timing Belts, Fiberglass Reinforced Neoprene July 10, 2007 The Econobelt Line features timing belts in 11 different profiles. Made from fiberglass reinforced Neoprene, these belts are available in...Read More
AAC's New Heavy Duty Stainless Steel Vibration Mounts Designed for Corrosive Environments July 9, 2007 A new series of 3 heavy-duty base mounted vibration and shock isolators by Advanced Antivibration Components feature stainless steel mesh...Read More
New Vibration Mount Catalog V100 from AAC Features Over 1,270 Off-the-Shelf Shock and Vibration Damping Components July 9, 2007 Finding the right vibration mounts for your application has become easier with the publication of a new 240-page catalog "Shock and ...Read More
Hainbuch Produces Large Mandrel With Significant Clamping Range for China July 9, 2007 Hainbuch GmbH produced a workholder that weights 1.3 tons and features a clamping range of up to 420 mm.According to the company's pr...Read More
ITW Rocol's Lubricant Applied to Grinding Wheels to Increase Belt Life July 9, 2007 Accu-Lube Stick lubricant is a ready-to-use lubricant stick that is applied to the tool before start-up. Accu-Lube Stick can be used on g...Read More
