Precise positioning of semi-conductor wafers during SCARA assembly operations requires instantaneous braking and holding power while minimizing heat in the system. The latest compact and slender Miki Pulley BXR-LE brake models provide the needed perfectly controlled braking in a confined area of the system using minimal power.
Festo introduces its newest generation of Cartesian-handling-system mechanical axes. The ELGD-TB, tooth belt actuators, and ELGD-BS, ball screw actuators, are based on an innovative Festo design.
Firmly committed to Industry 4.0 and the future of manufacturing, KUKA Robotics will highlight an innovative solution for educating the next generation of workers and its collaboration with three universities on cutting edge Mixed Reality (MR) demonstrations at Automate 2024, May 6 – 9 at McCormick Place in Chicago, Illinois.
Ruland Manufacturing now offers bellows and double disc couplings with bore sizes up to 1-3/4 in or 45 mm for use in systems with torque up to 1,4000 in-lbs. (158 Nm). High torque applications commonly found in precision semiconductor, solar, conveyor, and factory automation applications often use these shaft sizes. Ruland disc and bellows couplings accommodate all forms of misalignment, are zero-backlash, and have a balanced design for reduced vibration at speeds up to 10,000 rpm.
Automate, North America’s biggest robotics and automation trade show, will open its doors on May 6-9 at McCormick Place in Chicago. Stäubli Robotics will present exhibits, live demonstrations, and experiences at Booth 2250, featuring flexible robots adapted to improve safety as well as productivity in a variety of manufacturing environments, from heavy industry to highly aseptic, and meet user needs across sectors.
This week at Hannover Messe, Dana Incorporated is highlighting its broad range of next-generation motion systems offering superior performance, durability, and sustainability across the entire spectrum of industrial applications. Located in Hall 6, Stand D48/1, Dana will feature its recently updated Brevinigearboxes and winches, as well as field-proven GWB industrial driveshafts.
NSK Ltd. has released a new gas turbine generator bearing for eVTOLs including large drones, which is expected to extend drone flight range. The new product was used for the gas turbine generator of a large drone (high payload emergency supply delivery drone equipped with a gas turbine generator) equipped with an 80-kw hybrid drive system for a regional reconstruction and practical development promotion project in fiscal 2023 and delivered to Fukushima Prefecture on February 21, 2024.
