Engineered with precision and versatility in mind, the MTB 105 is specifically designed to integrate into multi-axis medium- to large-sized Cartesian Gantry systems, providing robust support for medium to high payloads. Its fully enclosed design ensures reliability even in contaminant-prone environments, making it an ideal choice for a wide range of applications. Precision extrusions for each aluminum actuator body ensure all sides and bottom surfaces are flat and perpendicular giving accurate installations.
Thomson Industries, Inc. has announced the availability of new German-engineered precision ball screw sizes with US-based distribution and machining that provide best-in-class load capacity in a small footprint. The Thomson miniature metric ball screw line uses a unique multi-start ball return design that maximizes support for higher loads. This design provides precise, smooth and quiet operation for applications requiring high precision and load handling in confined spaces.
When an application calls for synchronous lifting and pushing of a heavy load, rack and pinion jacks are an easy-to-use, economical and effective option. They combine a simple structure, robust design and a wide range of lifting forces, making them highly versatile and particularly attractive for installation in tight spaces and harsh environments. In fact, rack jacks can be installed as a complete system with many configurations, connected to air cylinders and motors, to guide forces to wherever they are needed in complex applications.
ABB Robotics has announced its first Flexley Tug T702 autonomous mobile robot equipped with AI-based Visual SLAM navigation technology and the new AMR Studio software, enabling first-time robot users to easily program and operate entire fleets of mobile robots. The new capabilities simplify configuration and can reduce commissioning time by up to 20 percent, paving the way for a workplace where intelligent robots operate autonomously, amid a critical shortage of skilled labor.
Heidenhain is pleased to announce its participation in the EXPOMAQ show (Booth #418), from June 18-20 at Poliforum León in Guanajuato, Mexico. As the leading exhibition for metalworking, machine tools, and manufacturing technology in Latin America, EXPOMAQ brings together industry experts, professionals, and leaders, making it a pivotal gathering for those keen on exploring advancements in state-of-the-art technology.
Intralogistics solutions provider Kardex appeared at Automate 2024, North America’s largest robotics and automation event in Chicago (May 6-9), demonstrating the fastest order fulfillment solution per square foot on the market. Kardex FulfillX is a warehouse execution system (WES) purpose-built to allow new AutoStore systems to ramp up faster and is capable of meeting or exceeding business cases in as little as six months. It has been specifically created by experts at Kardex, a global AutoStore partner, to maximize the capabilities of AutoStore robotic cube storage systems for manufacturing customers.
The ATR-V-60-60 Series (-01 thru -04) of Dual-axis Elevator-Rotary Stages has been released by Optimal Engineering Systems, Inc. (OES). These compact, Elevator-Rotary Stages feature a high stability Elevator Stage with 120 mm x 80 mm table and 60 mm +/- 2 mm of vertical travel and a load capacity of 5.0 kg. A 60 mm diameter Rotary Stages is mounted vertically. The scissor lift design of the elevator stages combined with precision roller bearings and slide rails assures smooth motion and very high parallelism throughout the travel of the table. The rotary stages capable of continuous rotation feature high precision bearings and 90:1 worm gear.
This Intellidrives waterproof and dust-resistant linear slide motion axis is engineered for reliability in harsh environments. With IP43 ratings, it withstands water and dust ingress, ensuring seamless operation in wet or dusty conditions. Ideal for outdoor use, marine applications, or industrial settings prone to moisture and debris. These axes offer precise and smooth linear motion control, enhancing automation systems' performance.
Back in 1913, in Ann Arbor, MI., Leander J. Hoover founded the Hoover Steel Ball Company. In 1990, Tsubaki Nakashima company of Japan acquired the US ball manufacturing company and is currently the biggest manufacturer and supplier of precision balls in the world. Its first markets were the growing automotive and precision bearing industries. More than a century later, the electric vehicles (EV) market is becoming more and more relevant, though the combustible auto industry continues to grow. Its market for high-quality precision products has extended to medical, aerospace, military defense, and critical applications. After the great age of steel, a new era opened wide spaces for more extreme materials which paved the way for ceramics.
