Third-quarter earnings confirmed
the worst-case scenario — plunging oil prices are whacking almost the entire industrial sector. The theme is hardly new, as the pattern of our headlines has revealed over the past fifteen or so months:
Guy Gendron, certified bearing specialist and technical sales representative at Timken Canada L.P. explains how he used his bearing expertise to increase a customer’s productivity.
finished products.
Power Transmission Engineering is collaborating with the Bearing Specialists Association (BSA) on a special section within the magazine. Bearing Briefs will present updated reports on bearing topics for each issue in 2016. Complimentary access to all BSA Bearing and Industry Briefs is available on the BSA website at www.bsahome.org/tools. Additionally, our new Field Notes section on page 34 will feature field reports from BSA’s Certified Bearing Specialists.
Mechatronics simplifies traditional engineering concepts across most
industrial segments. By combining mechanical, electrical and computer technology into a single, integrated solution, products become systems
that are more efficient, reduce
operator error and cost less to
manufacture.
Third-quarter earnings are confirming the worst-case scenario, i.e. — not only are energy related end markets in a downturn, but conditions continue to worsen.
