OES (Optimal Engineering Systems, Inc.) has added vertical stages to their extensive line of high accuracy, high resolution lift stages. The Z110 Series of Z-axis Stages are available in travel strokes of 15 mm (0.590 in.), 30 mm (1.181 in.), 50 mm (1.969 in.), and 75 mm (2.953 in). These black anodized aluminum alloy stages feature preloaded crossed roller bearings and 1 mm per motor turn lead screws.
The Smart Function Kit Pressing, a complete mechatronic package from Bosch Rexroth for the quick realization of servo presses, is now available with force control. This means that it is now also possible to perform processes in which the target force must be kept constant over a defined period of time. Intelligent e-tools speed up the selection and configuration of the modular servo press. The pre-installed operating software facilitates quick and easy commissioning, process definition, and line integration.
Dual loop control is often used to improve the performance of a motion control system. Although this appears more complex at first look, the overall system cost and complexity needed to reach the desired level of precision may often be significantly reduced. In the example system, mechanical stiffness was improved by a factor of approximately 100 by the use of a secondary feedback device.In the case of a single loop lead screw system, the feedback is usually located on the back of the motor.
Schneider Electric announces major enhancements to EcoStruxure Resource Advisor, a versatile enterprise software suite of solutions designed to empower global companies across efficiency, ESG, energy and risk, and renewables and carbon. This strategic evolution from a platform of stand-alone solutions to an integrated and multifaceted suite addresses the rapidly maturing market and the increasing complexity of corporate sustainability needs.
In Watch Valley, a region between Basel and Geneva, an ecosystem has developed over several centuries around the watch industry and the smallest precision components for micromechanical devices. Machine builders such as Esco SA in Les Geneveys-sur-Coffrane and Affolter Group SA in Malleray are an important part of this ecosystem. Their CNC machines are used to manufacture the smallest gears, screws, shafts, and other components at maximum precision, practically laying the foundation for the famous precision of Swiss watch movements.
Servo Technology has gone through various key stages of evolution, from the Power Transistors (Servo 1.0) and DSP/Microprocessor (Servo 2.0) to the Integrated Packaging (Servo 3.0) and Industrial Network (Servo 4.0). We are now entering the new era in servo evolution called Servo 5.0, where the intelligence and connectivity, in align with the emerging Industry 4.0 effort, are now required in the traditional servo control products.
