The Factory Automation (FA) Integrated Selection Tool allows customers to plan and configure their Mitsubishi Electric machines, resulting in a downloadable Bill of Materials (BOM).
Moticont has released the GVCM-022-013-01 Linear Voice Coil Servomotor. This compact .875 in. (22.2 mm) diameter high speed, high force-to-size linear motor features high accuracy and high repeatability when operated in a closed loop as a DC servo motor. This brushless servo motor is clean, quiet and has long life, low mass and high acceleration/deceleration for high throughput.
With the SINAMICS S210 next generation servo drive system, comprising a digitally native drive with wide range of corresponding motors and gearboxes, Siemens brings a new level of high-dynamic, motion control in mid-range operation to stand-alone and multi-axis machines. This next generation servo drive system introduces a new level of safety and security to discontinuous motion control in the mid-range segment, as well as moving, processing and positioning functions on a wide assortment of packaging, printing, labeling, pick-and-place, stacking, assembly, chip sorting and filling machines, with a special emphasis on food-and-beverage and pharmaceutical applications, owing to the availability of stainless-steel motor and planetary gearbox options.
Advanced Motion Controls (AMC) is proud to announce the addition of six new CANopen servo drives with Extended Environment capabilities to their FlexPro line. These new drives join AMC's existing EtherCAT Extended Environment FlexPro drives, making the FlexPro line the go-to solution for motion control applications in harsh environments.
Kollmorgen has announced the new AKD2G 24A drive. Designed for applications in precision multi-axis servo systems, the new single-cable optimized drive builds upon the strengths of the AKD2G portfolio including upgraded safety features, SD card backup and a graphical display with higher amperage to support more applications with higher power requirements such as conveyors and vertical lifting applications.
