Igus, a global manufacturer of motion plastics, has developed intelligent two- and four-hole fixed flange bearings with wireless sensing capabilities for wear detection, enabling condition monitoring and preventing costly machine breakdowns.
AutomationDirect has added more ProSense XTH2 series fixed range, head-mounted temperature transmitters to their lineup of temperature transmitters/signal conditioners. The XTH2 series fixed-range transmitters are for Type Pt100 3-wire RTDs and are ready to use out-of-the-box with pre-configured measuring ranges up to 500°F (260°C).
SKF has expanded its portfolio of Condition Monitoring solutions with the SKF Enlight Collect IMx-1-EX sensor solution. Wireless monitoring of assets helps predict machine failure before it can escalate into a serious problem, such as an unscheduled shutdown. This can deliver multiple benefits, including reduced costs and a more sustainable operation of equipment.
How does one accurately examine the components in a robotic arm or prosthetic leg? There’s not exactly time (nor space) to set up multiple cameras to track deformation or changes in shape of soft components.
Bega Special Tools introduces a portable multi-purpose induction heater on the North American market. The MF Quick-Heater 3.0-3.5 kW can be used for mounting, dismounting and pre-heating purposes. Weighing less than 8 kg and fitting in a small carrying case, this easy-to-use but powerful tool is just plugged into the mains 230 V. It can be used in difficult circumstances where other systems are impossible to operate, for instance where there is little space to work in or where no open fire is permitted. The heater’s flexible inductors are ideal for a large variety of parts with a maximum diameter of 120 mm. Application examples can be found in all types of industries.
Digital transformation is one of the most effective approaches to help today’s CPG companies solve productivity and sustainability challenges. There are new and emerging automation technologies that CPGs can integrate within production lines to reduce energy consumption, streamline processes, increase machine availability and drive new levels of productivity and sustainability.
Heidenhain Corporation announces its participation in the Canadian Manufacturing Technology Show (CMTS), taking place from September 25-28th, 2023, at the Toronto Congress Centre, North, in Etobicoke, Ontario.
Heidenhain Corporation announces its participation in the upcoming NAEC (National Association of Elevator Contractors) 2023 Convention & Exposition. Connecting professionals from all over the elevator industry, NAEC will take place from September 10-13 at the Reno-Sparks Convention Center, Nevada.
In lithium-ion batteries, higher energy density increases the risk of thermal runaway. As a preventive measure, Freudenberg Sealing Technologies has developed thermal barriers that help to slow down thermal runaway by increasing resistance to propagation. The new 3D thermal barriers can be used at various positions within the battery and have already proven reliable in their initial series productions.
