Binder, a leading supplier of industrial circular connectors, offers products from several M12 series as surface-mount devices (SMDs). These are suitable for further processing in fully automated processes, such as for the particularly dense, double-sided assembly of PCBs. They are also used in automation technology devices, sensors, actuators, and robotics.
The international automotive supplier Forvia Hella receives the John Deere Award in the sustainability category. The leading manufacturer of agricultural machinery honors Forvia Hella for its heat recovery system at the Großpetersdorf site in Austria. The system saves around 175,000 kilowatt hours of natural gas per year and therefore around 32,000 kilograms of CO2. The award was presented at the John Deere European Supplier Conference in March 2024 in Mannheim, Germany.
Artists Bruce Rosenbaum and Ben Cowden earned film credits recently for prop design on the PBS documentary The Lie Detector: A Truly Unbelievable Story. This ambitious historical account of real-life inventors, marketers, law enforcement professionals, and snake oil salesmen traces the interconnected lives of John Larson, William Marston and Leonarde Keeler.
While the factory has received a modern makeover in recent years, it’s no surprise various industrial segments are taking advantage of digital tools to promote efficiency, sustainability, and productivity. The farming and agriculture community has embraced automation, robotics, IIoT, drones and autonomous vehicles to address global food demands and production limitations.
PCB Piezotronics (PCB) is introducing the new Endevco Model 7330 triaxial angular rate sensor. It provides accurate measurement of rotational velocity in a small, lightweight package rugged enough for extreme environments, such as automotive safety testing.
Igus, a global manufacturer of motion plastics, has developed intelligent two- and four-hole fixed flange bearings with wireless sensing capabilities for wear detection, enabling condition monitoring and preventing costly machine breakdowns.
AutomationDirect has added more ProSense XTH2 series fixed range, head-mounted temperature transmitters to their lineup of temperature transmitters/signal conditioners. The XTH2 series fixed-range transmitters are for Type Pt100 3-wire RTDs and are ready to use out-of-the-box with pre-configured measuring ranges up to 500°F (260°C).
SKF has expanded its portfolio of Condition Monitoring solutions with the SKF Enlight Collect IMx-1-EX sensor solution. Wireless monitoring of assets helps predict machine failure before it can escalate into a serious problem, such as an unscheduled shutdown. This can deliver multiple benefits, including reduced costs and a more sustainable operation of equipment.
How does one accurately examine the components in a robotic arm or prosthetic leg? There’s not exactly time (nor space) to set up multiple cameras to track deformation or changes in shape of soft components.
