The demand for a high accuracy, robust, open-frame stages is met with Intellidrives dual-axis, large aperture stages that address the unique needs of scanning microscopy, wafer and printed circuit board inspection, automated assembly and wide range of specimens and samples scanning in many types of imaging techniques and applications.
The Timken Company has reached an agreement to acquire Nadella Group, a leading European manufacturer of linear guides, telescopic rails, actuators and systems and other specialized industrial motion solutions, from ICG plc.
Thomson Industries, Inc., a leading manufacturer of linear motion control solutions, has introduced a family of compact linear systems that makes it easier for motion designers to implement complex applications in small spaces. Designers needing thrust and bearing support in a single, compact unit now have the flexibility to build such applications with versatile, time-tested components from Thomson.
Intellidrives EtherNet/IP compatible Motion is a scalable and comprehensive solution that provides a common application interface and services for general purpose I/O and motion control that is fully compatible with standard Ethernet/IP topologies, minimizing integration effort with Ethernet/IP-based PLCs.
Offering a track with stronger magnets for their linear motors than previously available, ETEL introduces the new MWD+. This magnet-track family is compatible with any existing LMG and LMS linear motor from ETEL, enabling up to 15 percent higher continuous and peak forces compared to the existing MWD product.
Optimal Engineering Systems, Inc. (OES) has released four new high resolution, high repeatability XY Alignment Stages. The AU200-120x120 Alignment Stages feature 120 mm (4.724 in.) of travel in both the X and Y axes. These new low profile 87 mm (3.425 in.) high XY stages, have a 188 mm x 188 mm (7.401 in. x 7.401 in.) open aperture. Easy integration of tooling and fixtures is facilitated through a precision series of threaded mounting holes.
SMAC Moving Coil Actuators recently introduced its new LPL Series 125 low-profile electric linear actuator designed specifically for use on robot end effectors.
