Designing linear motion systems for washdown applications requires careful component selection to solve problems associated with contamination as well as liquid and chemical interactions.
December 1, 2023
This article examines the sound engineering practices and design principles needed to ensure the performance of mechanical linear motion components in sanitary washdowns or chemically cleaned environments. Relevant regulations and agencies, washdown-compatible materials, and best mounting practices and motion components for washdown applications are also discussed.
Bearing Specialists Association (BSA) and the Power Transmission Distributors Association (PTDA) announce the introduction of seals, linear bearings profile rail, bushings (hub fixing devices), chains and sprockets to the PIE Technology Platform (PIE).
Motion Industries, Inc. named NSK “2022 Supplier of the Year.” The award recognizes companies that have shown exceptional commitment to Motion through quality products and services and earned the highest score in the multi-faceted Supplier Stratification rating system. The presentation took place July 18, 2023, at NSK’s manufacturing facilities in Franklin, TN.
Rollon has introduced its TLS Series of telescoping linear actuators. The new series is designed to maximize productivity for applications where space is limited — especially for applications with minimal vertical clearance, such as between the machine and ceiling, or horizontally between machines.
Fixtureworks (Fraser, MI) a North American manufacturer and supplier of clamps, fixturing accessories, machine tool components and rollers & bumpers, now offers a line of mechanical linear actuators.
Intellidrives new overhead XY gantry built with precision ball screw actuators and are offered in travel length from 100 to 600 mm. They can be motorized with stepper motors, brushless servomotor/encoders or integrated Smart motors.
IKO is pleased to announce that Jeff Williams has joined the company as national distribution sales manager. Contributing to IKO's efforts to build and enhance relationships with valued customers, Williams will be based in Parsippany, NJ and will work closely with distributors and sales teams.
Motion Plus has announced the release of the Motus1 (M1) industrial positioning actuator. This new addition brings a belt- and screw-driven industrial linear positioner for superior performance to Motion Plus's already broad portfolio of in-stock, high-quality automation components.
