rotary-type blowers? Examples: for motor KW; RPM; temperature; pressure production; lifetime; etc.
In other words, how do I choose between belts or couplings?
Wind turbine gearboxes are subjected to a wide variety of operating conditions, some of which may push the
bearings beyond their limits. Damage may be done to the bearings, resulting in a specific premature failure mode
known as white etching cracks (WEC), sometimes called brittle, short-life, early, abnormal or white structured flaking
(WSF). Measures to make the bearings more robust in these operating conditions are discussed in this article.
The growth of worldwide energy consumption and emerging industrial markets demands an increase of renewable energy shares. The price pressure coming from coal, oil, nuclear and natural gas energy - combined with enormous worldwide production capacities for components of wind
turbines - make wind energy a highly competitive market. The testing and validation of gearboxes within the test rig and the turbine environment attract a strong focus to the needs of the industry. The following contribution sums up the typical process requirements and provides examples for successful system and component verifications based on field measurements.
